O
Okan
I have installed a double socket in a hall and taken the feed directly from the existing 32a MCB in the CCU. The MCB already has a final ring on it. My question is which certificate would i put it on?? Is it an installation cert because it feeds directly from the circuit protector, or is it classed as a spur and will then be a minor works cert. Any help would be apreciated
