Which Certificate? | on ElectriciansForums
Discuss Which Certificate? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
spadxiii1918
I have a situation where the ring circuit had gone down on the return leg from board to socket. (32A MCB).
I downrated the MCB to 16A to protect the cable. (Customer not keen on flooring coming up to replace leg etc.) But as this changes the electrical characteristics of the installation, which form would I need to satisfy part P. Would it be a minor works or a test and inspect cert?, although the installation may clearly not be to BS7671 2008.
Any help or advise would be Aappreciated.
Mark
Reply to Which Certificate? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Here the BPG#4 is useful, it is not a statutory document at all, but it provides good guidance as to what can reasonably considered as C1/C2/C3...
