which code is this one? | on ElectriciansForums
Discuss which code is this one? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
for an inspection, the consumer unit is only about 100mm above gas meter, which code do you guys think? i am thinking this is dangerous and have given code 1.
Hi, i'm new but have been a spark for over 10 years, I had this on a ELECSA inspection, the fuse board was about 100mm away from the main gas meter i mentioned it and showed the inspecto,r he said that it was ok as it was installed before the reg's got so tight. I still noted it and put it as a 4.
Cheers
Well the recommendation is a minimum of 150mm....so IMO 50mm closer doesnt suddenly become dangerous.....I would code 4...but accept it is down to the inspector to use his judgement.
I would code 4 it. Interestingly the gas fitters I come across dont seem to have a clue about this reg or the 75/50mm from a gas pipe to an elec cable.
Reply to which code is this one? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The coding part is all down to experience and knowing whether something is right or wrong. Remember some pics have no faults.
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
