The customer has a bulk standard axial fan located in the ceiling of a small shower room (approx 2mx1m). The shower room has no door, just an L shape into shower from bedroom.
The ducting goes through the loft at a run of approx 5 meters. It pretty much starts off vertical for around 1 meter and the ducting continues along the ceiling of the loft and eventually out through the eaves.
The chap says he has lots of condensation coming into the fan and it now stays on continuously even with the light off.
I dont like the long vertical run as it just asks for condensation to fall back into the unit so would be locating ducting along floor of loft. My question is which fan for the long run? An in-line fan probably but I am unsure of what m[SUP]3[/SUP] p/hr is required. Also m[SUP]3[/SUP]p/hr seems to be dependant on the area of the shower rather than length of ducting? Is a higher m[SUP]3[/SUP]p/hr going to be better for a long ducting length or should I be looking at a different form of fan (centrifugal??)?
Thanks all..
Thanks all..
