which is the besst way? | on ElectriciansForums
Discuss which is the besst way? in the UK Electrical Forum area at ElectriciansForums.net
T
thekingiam
rewired all the house and forgot about light in pantry where consumer unit is.
would it be beter to run a cable from cu and put an extra mcb in, i have to put a socket in there as well from a 16 mcb so i could connect from the socket to a fcu into lighting circuit as well which would you do?
You don't need a whole new circuit. Also if you add a new circuit then it's notifiable.
Personally i would add another connection to the existing downstairs lighting MCB and run that to the pantry switch/light.
Run a spur from the consumer unit's downstairs socket mcb to power the socket.
i was thinking of running a cable to existing lighting mcb but was thinking of segregation of circuits. i suppose it makes no difference as the mcb controls lights,what about when i come to test would i group it with all lights on that mcb?
if i connected the socket to the 32 amp ring main mcb when i come to test would i use this spur to get my readings for R1 and R2.
I would have thought better to come off the upstairs lighting circuit, at least then you would have light in the pantry to see what you are doing at the CU, if the downstairs lighting breaker tripped.. lol!!!
wouldn't want to pull back cable as i have had difficulty getting all cables to cu as it is .
as you can see not much space to drop cables. lighting cables in 25 mm trunking on the right and i need them on the left, running a new circuit from cu would save me alot of sress and effort, would i need a seperate mcb for 1 light or connect to existing mcb in cu?
[ElectriciansForums.net] which is the besst way?
Reply to which is the besst way? in the UK Electrical Forum area at ElectriciansForums.net
Haha yes, it is. Must be a northern expression. Have a Google 😂
