which is the current easiest T & E to work with ? | on ElectriciansForums
Discuss which is the current easiest T & E to work with ? in the Electrical Tools and Products area at ElectriciansForums.net
LukeD
Nearly Esteemed
Supporter
I like Prysmian cables . But would like to know if there are better ?
Prysmian is the best imo
copper cable company is good
when I first started house bashing I used a lot of ABB wessel which is ok
some of the non branded stuff I have picked up from the Diy sheds while in a pinch has been hit and miss
Doncaster cable used to be good, haven't seen it around for ages.
+1 for Prysmian.
With the price of it lately it could be a target for some low life!
Cable is surprisingly difficult to shift second hand compared to hand tools , power tools , general tools and other builders gear ...
Not a sparks, But a tree surgeon (Dope head) near me uses a open back truck .All his gear in the back etc during the day. Parked up to get a coffee . Heard a lot of people sounding their horns etc ... A bunch of Nomadic caravan dwellers had stopped their van in the traffic and helped themselves . He lost the lot . Including 2 mega expensive lawnmowers . Site/van tool theft is mental around london. They will do it directly in front of sites and "front" any owner .
If you see this T+E and especially SWA throw it in the bin its absolute trash
[ElectriciansForums.net] which is the current easiest T & E to work with ?
Is that the old Turkish carp that wholesalers were knocking out a few years ago , I had a roll of 1mm of that stuff and it was horrific to strip
Got a 100m roll of Prysmian 2.5mm² T&E and its pants, almost like they forgot the chalk. Even pulling 4" of sheathed off is an absolute PITA.
Must be a bad batch because, as you say, its normally the best.
I had the same thing with a couple of rolls of Prysmian T&E a few years ago - the outer sheath was well and truly stuck to the insulation. I wouldn't touch the stuff now and usually go for Doncaster Cables.
Found the same a couple of years back - one roll a pleasure to work with, but the next was a royal pain in the backside.
Reply to which is the current easiest T & E to work with ? in the Electrical Tools and Products area at ElectriciansForums.net
Job interview View: https://www.youtube.com/watch?v=uYKD1j5jEvs
Does it really actually need earth sleeving inside the tube? I know it feels a bit bodgy but what's going to happen and isn't an unbroken...
