Which LED driver? | on ElectriciansForums
Discuss Which LED driver? in the Talk Electrician area at ElectriciansForums.net
serious
Hi,
I would like some advice on LED's. I have four LED's which came as part of a set with a transformer. The LED's are designed to be recessed and can be ceiling mounted as down lights. The four LED's plug into a splitter which connects to a single transformer which is plugged into the mains with a three pin plug.
What I want to do is split each LED so that each is powered and switched separately. So I would like to buy four LED drivers and drive each LED separately. My problem is I do not know which LED driver I need?
Each LED is marked as follows: BLUE LED
WATT: 0.5W
OP VOLT: 5V DC
IP54
The transformer is marked: AC 100-240V 50/60Hz 0.2A
O/P: DC 5V, 1A
So based on the spec of the LED which driver would I need? The term "OP VOLT: 5V DC" confuses me :confused:, drivers I have seen so far are rated 12V.
Any help appreciated.
Reply to Which LED driver? in the Talk Electrician area at ElectriciansForums.net
Assuming the electrician checked the new driver was capable of supplying current (in other words it provided an output voltage and curent when...
