Which mounting rail do you suggest - please | on ElectriciansForums
Discuss Which mounting rail do you suggest - please in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
supersports
I have just made up frames for my groundmount for 16 suntech 190's , manufactured out of galvanised box section, the space between each frame is 1.8m , all connected together with a support beam, which rail type would you suggest that will be robust enough to support the panels between frames and a suitable fixing method to attach rail to frames.
Darren
Reply to Which mounting rail do you suggest - please in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
