which multi function tester?? | on ElectriciansForums
Discuss which multi function tester?? in the Electrical Tools and Products area at ElectriciansForums.net
H
harl
hi all was thinking of buying a multi function tester but not sure what to buy i have been looking at metrel but a mate has brought a fluke 1653 (nightmere which tester)
any help please
regards
dave
our company tend to like the metrels probably because the're cheap they seem susceptibleto going funny whaat was happening was when i went from ir test back to continuity the meter wouldnt settle down even when leads were compensated i found a way of settling it down but it probably compromised the life expectancy of the meter!!!!
i use meggers
they're ok but soooo slow on the no-trip loop function (which is pretty much all you will use for Zs under the 17th)
also you have to shell out extra to get the plug top lead for measuring your cross connects when doing rings!
Reply to which multi function tester?? in the Electrical Tools and Products area at ElectriciansForums.net
KT66EVA (KT66DL & KEWEVA) - ÂŁ1073.60 + VAT if you shop about as a combo
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
