Which qualifications | on ElectriciansForums
Discuss Which qualifications in the The Welcome Forum area at ElectriciansForums.net
Leicester
Can someone please help.
Which city and guild qualifications do I need to work as domestic installer.
As in do electrical work at customers house and sign work off.
I have part p plus 18th edition bs7671
Would I just need to do the 2392-10 testing and inspection as well?
if you will be doing notifiable works, then contact one of the scams, niceic or whatever, and ask what they require (in addition to fat cheques each year).
What he said, ^^^^^^^^^^^^^^^^^^^^and some experience of course, scams won't tell you that though, all they want is your dosh, but you can have that advice for free.
You need experience and knowledge, and you can never have too much of either. If any of the schemes take your stated quals as evidence of that then it's an absolute joke.
but we don't know if the OP has had some practical experience or not. never judge before learning all the facts.
Most schemes require the same kind of things. NICEIC require at least 2382-18 and 2393-10. They will also want to inspect a job that you have completed recently so that they can prove you are competent. The links below are only for a couple
https://www.stroma.com/media/part-p-brochure.pdf - page 6
https://www.niceic.com/medialib/www.niceic.com/Schemes/CPS-Reg-Guide-Dec-18-Web.pdf
Cant quite see how inspecting 1 job you have completed, will ratify your so called competency.
Reply to Which qualifications in the The Welcome Forum area at ElectriciansForums.net
NICEIC Certification Scheme NICEIC Competant person scheme
This sounds very similar to me. My level 3 NVQ is in engineering maintenance and I also have a HNC in Operations Engineering. I’ve been working...
Posts on this forum suggest it is no longer a means of entry to 'domestic installer' schemes. I'm happy to stand corrected as Part P is simply...
nicebutdim
N
