ringer
I don't normally get involved in this but have been asked by customer to fit smoke alarms - this is for a property that will be rented out. I know that mains powered smokes used to be the way to go in this situation as tenants tended to take out the PP3 batteries to use in other equipment. Nowadays though you can get sealed in 10-year lithium versions which to my mind negates the 'battery removal' problem. Fitting these battery powered ones is clearly the cheaper option for my customer as he does not have to pay for me to install wiring (converting existing premises so access for new cabling is not easy) and gives greater flexibility in fitting them in the ideal position (rather than only where it might be possible to get a cable to it). I understand that even mains powered smokes need replacing every ten years, so what are the benefits of fitting mains powered smokes these days?
