Which source drive the star delta contactor | on ElectriciansForums
Discuss Which source drive the star delta contactor in the Australia area at ElectriciansForums.net
L
layzbass
Hi sorry for my newbie question, I've a question about a star delta starter. What exactly drive the mechanical contact in contactor, is't AC 240/220V separate source from L1,L2,L3? thanks.
a contactor is a large relay. It has an electric magnet inside it, called a coil. the connections for this are usually labelled as A1 and A2.
when the coil is energised, it will pull the contactor in, and operate either normally open (NO) or normally closed (NC) contacts. The coil can be fed from the same source as the contactor, or from a different MCB, or as is often the case, through an ELV transformer.
[ElectriciansForums.net] Which source drive the star delta contactor
Please find the picture above,the D.O.L diagram. Anyone can tell me how the auxiliary NO working base on the schematic diagram. Tq
Reply to Which source drive the star delta contactor in the Australia area at ElectriciansForums.net
I believe that it is incorporated into the 5 days. But will double check. Thanks.
