Which Switch do I need for a 7.2kW Rated Induction Hob? | on ElectriciansForums
Discuss Which Switch do I need for a 7.2kW Rated Induction Hob? in the DIY Electrical Advice area at ElectriciansForums.net
J
James81
Hi,
I was looking at the MK switches as we wanted
them to match with the sockets.
But they only have a 32A switch which
matches, the 50A switch is quite large.
Will the 32A switch be ok for this induction hob?
7200/230= 31.3
looking at volts and amps looks like it will be right enough.
make sure you terminate it properly, theres bit of a load going on, if theres a loose connection it will end up in flames.
or get an electrician in for a little job.
Reply to Which Switch do I need for a 7.2kW Rated Induction Hob? in the DIY Electrical Advice area at ElectriciansForums.net
allowing for diversity a 32 amp supply will be fine for them both, but remember, the cable needs to be adequate to cope with a load on up to that...
N
He hasn't provided any certificates, including previous work. He sends invoices when he needs paying.but no vat registration number etc on...
  • Nessab16
  • Ireland
  • 8
  • 524
Nessab16
N
