Hi I am trying to replace my bathroom tap with a new one, I am trying to remove the existing rusty flexible tap connectors from this bit of 22mm copper pipe.
But this thing is not budging at all its like its welded or super glued on, I am using some water pliers on both points here but its not loosening up and grip is not so great trying to do 2 water pliers and turning in opposite direction. I have installed flexible tap connectors before but never this tight.
Are these ??? parts the points I should apply the water plier grips to?
Maybe better tools can be recommended for me also, thanks
Continue reading...
Which tool to undo stubborn tap connector?
Plumbers Forums
Thread Tags
Raff,
