White Cooker Switch | on ElectriciansForums
Discuss White Cooker Switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Use a Crabtree instead its better made and a couple of pounds more but then again just fit it and in 5 years I will get the callout to replace it and it will be crabtree
Click do a white one as well (with socket and without), think MK does as well.
Never could work out why so many are sold with gash orange or red switches
or why the original MK cooker control unit was the size that it is...
There is no reg to say that the switch itself must be red or orange. As long as its got what post 4 wrote then is ok.
also I think for 45-50A switches the contact desperation distance should be 6mm that's why there harder to switch.... Unsure correct figures tho if anyone wants to enlighten me.
Reply to White Cooker Switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
J
The rcd spur being fitted is probably because there wasn't rcd protection of that supply.
