White switch plates | on ElectriciansForums
Discuss White switch plates in the Electrical Tools and Products area at ElectriciansForums.net
L
LCV
Hi,
I a looking for good quality white plastic 3 to 4 gang switch plates that can be a mixture of dimmers and rockers. I have been to a couple of Electrical stores and they only display the Hamilton range. Are there any other brands worth considering aside from Hamilton?
Also, I am looking for flat brushed steel plug sockets, they have Heritage Brass on display, so again, are there other brands worth looking at too?
Many thanks!
For the 4gang you might be better off with a grid switch system, the ones in the pics I've posted are MK.
  • [ElectriciansForums.net] White switch plates
I second or third the click range, good stuff, easy to use, available in a range of different finishes and the switches are interchangeable (except for the new media range).
The ingot style is good for something like stainless steel because the switches are the colour of the back plate.
Reply to White switch plates in the Electrical Tools and Products area at ElectriciansForums.net
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
Thanks, it says under the picture of the 4 front plates (in the tiniest writing possible) "Excluding the definity grid pro front plates which do...
