who can certify? | on ElectriciansForums
Discuss who can certify? in the Electrician Talk | All Countries area at ElectriciansForums.net
AJ16
Is it poss for another sparks to certify another persons first and 2nd fix in a house extension? My sparks didn't return to get paid after I mentioned certification.
off the record, yes you can, in a situation like urs and there not quailified to test and have legged it for some reason, you can call a qualified electrician, to come a look at all the installation/test, although he would have needed to be there during points of the first fix installation/2nd to be able to test it, unless the runaway sparkys were competent, but I don't see why not you can't do this, as its not your fault is it? thats if this/mystatement is true above. correct me if I am wrong, anyone
cheers
Thanks I'll give him another week then try that as I want to get it all signed off.
I can't understand why he has gone awol. He seemed alright but after I mentioned getting a cert he has not come back like he said he would. He also messed up on the smoke detector cabling but that not too major is it?
No he or any other spaks can't or more correctly shouldn't because;
1, he cant sign the design(er) section as he hasnt designed the installation.
2, he cant sign the constructor/installer section as he hasnt installed it.
3, he could test if competent to do so, but cant issue the EIC due to 1 & 2 above.
4, part P ....well NICEIC do not allow 3rd party certification or notification (i've asked).
5, No sparks worth their salt will sign off somebody elses work, who knows what or how may be installed behind plaster / under floors
The official line I got fromn NICEIC was
"get the home owner to contact LABC asking if they will accept a PIR from yourself but do not on any account issue an EIC, as you will then become responsible & liable for the installation & any faults/problems the 3rd party installer may have caused/installed. Make the home owner aware that they may be asked questions by LABC with regard to non compliance to building regulations & they will have to probably pay the LABC notification costs"
I get it done all the time as I can't sign off for myself (although I sign off for my company) and just pay someone to sign my work off. As long as they test it thoroughly it's fine. This bloody job is too full of pointless regulations that didn't exist until recently and it had done nothing but dtive the cowboys underground!
you can get 3rd party inspection and test ,we have done it when other firms have gone under,
a covering letter will have to suffice with regards a lack of designer ,constructor,installer
just be carefull guys who ever signs the work off, is then responsable for the whole job and if anything happens and it goes to court it will be your neck on the line. i personally would never sign off anyone else's work.
large companies have dedicated test depts they're signing off all the time
as everyone is warning tread carefully
I quite agree with EasyFox on this one
Yes many firms carry out 3rd party inspect and test (done a few myself), and where the designer and installer have signed the EIC, its quite acceptable. What isnt acceptable is to issue a PIR in place of an EIC!
And Cirrus, why cant you sign off yourself? And they can test it all they want, but which bit of the test would reveal such things as two lengths of 2.5 TW&E twisted together with a bit of tape around them under the floorboards? Or joined together with a connector block embedded in the wall? etc etc
Bottom line: covering letters aint worth the paper they are written on, because:- The sparks who signs off as designer and installer on the EIC, will be signing against "I, being responsible for......"
and that's it - he/she is then responsible. Would i sign off a sparks that done a runner?
Not a chance
I understand all your posts about testing etc, but what about for this one off sitution this person is in. Its not his fault, list what you think he should do.
thanks fellas I'll wait a while longer meanwhile may enquire anonymously at Building Control to see what the options are. I have a pretty good photo record of the wiring, so another sparks might do it if push comes to shove.
As far as I know it's ok but then that's not my area of expertise. Does it sound right though for the feed to the upstairs lights to pass through the wall box of a light switch with lives connected to common and the neutrals joined with a connector block?
But that's the problem Luke, its a one off for this poor chap, but common place for the working sparks. I personally have refused to do this a number of ocassions
He can call another sparks in, and the other sparks may sign it, but his question is 'Is it possible for another sparks to sign it off'. Well yes its possible, but the sparks will be accepting full responsibility for the work.
Sounds like its just been connected 2 plate method, as far as i am aware its perfectly acceptable.
Regards
MacSparky:)
I sign off for my company which isNIC registered but personally, I am not so don't sign off any of my own works as it would still mean notifying LABC which would cost me as much (if not more) than paying someone to sign off on my behalf
Reply to who can certify? in the Electrician Talk | All Countries area at ElectriciansForums.net
ESP - https://www.espuk.com/# is the company you are referring to part of Scolmore
Registration doesn't cost €75 - it's actually several hundred Euro. (€487.67 or some weird amount this year - it's risen quite substantially...
