who can do PIR | on ElectriciansForums
Discuss who can do PIR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
J
jmtisme
I am not yet a member of NICEIC but have been asked to do a couple of PIRs can I do them?
Yes you can
You can do them even if you never ever in your life join the Nic
The Niceic are nothing whatsoever to do with regulation of electrical works
They are a private company who keep a register of contractors they assess as competent
To use thier certificates,which are based on the IEE models,you would have to join them,same as any other organisations operating in the industry
If your not a member of any ,download and use the original IEE paperwork
Yes you can
Cheers Des spoke to technical helpline @ NICEIC and just about quoteded you word for word
liability for works and indemnity for professional advice given to others. remember the key word is competent as long as you are and you could prove it in court if needs be go for it. not being dramatic mate just making sure you are covered.
it would help to prove competence. still would need to prove you can make the call. if you have experience as a spark and your 91 mate i really would not worry about it. don`t forget it is a condition report after all and as long as you list the deviations you have nothing to worry about.
Reply to who can do PIR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
The existing wiring shows both brown wires into the same terminal. One should be in the terminal it is in now and the other in the terminal next...
