I have a couple of questions regarding small electrical works in a house, who can do them and whether a minor works cert is needed.
im trying to nail down an answer to the following.
i) Can a plumber / non-electrician replace a broken immersion heater in a water cylinder. i.e. unwire old one from the fused spur and wire in new one to fused spur? Is an qualified electrician needed? Is a minor works cert needed?
ii) With regard to replacing a like for like electric shower in a bathroom that has broken….can a plumber / non-electrician do this? Or is a plumber needed for wet part and electrician for electric side. Again, is a minor works certificate needed.
iii) With regard to replacement of a central heating component such as a zone valve or cylinder stat….is a minor works cert needed ? Can this work be undertaken by a plumber / non-electrician?
I’m trying to work out what plumbing works can be undertaken by anyone / a non-electrician and what works require both trades.
in the plumbing / heating trade there is cross over.
Many thanks for your time
