Why 3 Phase and not 6 or 12 - Video | on ElectriciansForums
Discuss Why 3 Phase and not 6 or 12 - Video in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
There are advantages and disadvantages for different phase orders, but two advantages of 3-phase are compelling: Zero common conductor current when balanced and only one more conductor than minimum needed to complete a circuit. In the early days it was competing with 2-phase, which shares the advantage of providing a rotating vector but with more torque ripple and the severe penalty of requiring more copper to transmit the same amount of power at a given voltage.
High order systems were better for rotary conversion and rectification with single-polarity rectifiers, e.g. a mercury arc (always common cathode) required 6-phase AC to give 6-pulse rectification, therefore a zig-zag transformer was used to derive this from a 3-phase supply. But with ordinary motors do not benefit from the mirror-image phases, and bridge rectification only benefits by reduced harmonics on the AC side and slightly lower ripple.
We have Ferraris and Tesla to thank for inventing polyphase systems in general and Dobrovolsky for making 3-phase the system of choice.
I think I need to go and do some reading up....I understood about 2/3rds of that....
Just to upset you even more. From a 3Ph input transformer it’s possible to get 48 phases out. Look for Mercury Arc Rectifiers on the other channel.
America has, as Lucian said 2Ph+N @90°, Tesla also designed a 4Ph+N system.
2Ph is still used in some out of the way places using Scott or LeBlanc transformers to convert from 3Ph. Normally they use 115/230V from a centre tapped transformers.
Take care not to confuse 2-phase with split phase - many US domestic supplies are split-phase 120/240 (sometimes derived from centre-tap-grounded delta 3ph) with both hots supplied to every consumer. But 2-phase has been obsolete for decades. I just had to look it up to see if it was still in use at all - according to Wikipedia, only in central Philadelphia.
While searching for a good illustration of the relative merits of the various systems I hit upon a silly error in a drawing in a reference book showing C/T and corner-grounded 4-wire systems. Some poor sod has got the high leg in his 120V circuit. US sparks will be familiar with this problem, while it is totally alien and incomprehensible to a UK spark.
Corner tapped ∆ is out of favor for good reason (earth fault currents) as is 90° 2Ph (weird Ph→Ph voltage. 325V for a 230V Ph→N supply). They are a hangover from the past. But they still persist.
A friend has a milking parlor in the mid west. The motors are 2Ph 90°, he sees no reason to change what is working. His father installed it originally now he, the son has retired. It’s worked up until this day, why change it? His farm is his hobby, he won’t change plus he’s got a shed load of spares.
Centre tapped 115/230V is the US normal supply.
Canada still seems to have a fair number of 680V corner tapped ∆ industrial installations.
Reply to Why 3 Phase and not 6 or 12 - Video in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As per above from Dave. Swap to a 63A outlet and problem goes away. What gets plugged into it is not part of an inspection.
