why a boiler on a ring main? | on ElectriciansForums
Discuss why a boiler on a ring main? in the UK Electrical Forum area at ElectriciansForums.net
L
ldpooley
I need this clarifyiing for a college exam(actually part of a plumbing course and why teachers cannot answer this)
why can a boiler run off a ring main and not for example, a cooker or immersion..
they tell us that everything else needs a radial circuit, but why is a boiler so special?
think the issue is more like that a cooker or immersion circuit should not have a boiler or other appliance connected to it's circuit,asthese areboth heavy loads and their respective circuits have been designed for them alone.
Loads 2kw plus should be on a dedicated circuit and not on a ring, been dedicated they should only supply the load they were wired for.
A gas combi - boiler only requires electric to power the controls and is a small load so can be taken of a Ring main or Radial socket circuit is required although requires fusing down, it is preferable if possible to give the boiler its own dedicated circuit as a fault on the ring main would also lose all the heating if it was taken off the ring main.
EDIT - bigspark - beat me to the post darn!...
Reply to why a boiler on a ring main? in the UK Electrical Forum area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
