why british plug are the best | on ElectriciansForums
Discuss why british plug are the best in the UK Electrical Forum area at ElectriciansForums.net
The quality of design of the 13A plug top is well known. The only issue I think it falls down on (and which I think is tested as part of some standards) is the 'pull-out' test. If someone trips over the flex, then the plug does not pull cleanly out of the socket, but can end up partially-removed, or can even come apart depending on the force.
The European/American plugs fare better that ours in this test. But only that one I think.
Daz
Daz
They fall flat on their face for every other test.
Geordie there's some info in its history here Wiring Matters 18 BS1363
At home I have a lengthy document describing the whole process blow by blow, with quotes from the people invoved. Its gestation was complicated by a number of external influences, e.g. Dorman Smith had already got their idea of a fused 13A plug underway before the committee had actually asked for designs. Clearly whoever was ahead in the game of creating a new national standard plug was likely to get some business from it.
We tend to be a bit protective about BS1363 in the UK, it's good but it's not better than every other plug in every respect.
But if you peel the plastic off you've got a nice slot where you can fit larger cables e.g. the thick one on the cooker
Reply to why british plug are the best in the UK Electrical Forum area at ElectriciansForums.net
😄 It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
Apparently so, I’ve copied and pasted below. Octopus Energy, named by the Renewable Energy Association (REA) as “the company that has done the...
