Why did 2 holes in my outlet turn blue | on ElectriciansForums
Discuss Why did 2 holes in my outlet turn blue in the USA Electrical Forum area at ElectriciansForums.net
OK. I'll try to send pic. Thank you
[ElectriciansForums.net] Why did 2 holes in my outlet turn blue
Any chance that there has been water seeping in to the back of the socket?
In any case the socket should be replaced, and if the cable is degrading that as well.
If it is only the socket (e.g. water damage) then that is a fairly easy DIY change if you have the knowledge, but if you are unsure in any way we would simply advise you to get a local electrician in to check/fix it. If you have any doubts about the advice/quotation from them then come back for more advice and one of our USA members such as @Megawatt is likely to be in a position to advise.
Thank you very much for your advice. This all makes sense to me now. I am calling electrician and someone to check my roof right away. I wasn't sure if roof was leaking in the next room in very small area along the crown moulding. I can't thank you enough for your reply!
Yes
Reply to Why did 2 holes in my outlet turn blue in the USA Electrical Forum area at ElectriciansForums.net
The best and easiest way to do it would be turn off the power and take the light switch out and splice the 2 wires on the switch together. Your...
Thats a Hager 3 gang rocker switch. Each is a single pole, 2-way switch (in UK terminology). 2 way switches are normally used where there is...
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
