I have got a new Mt1720 Megger tester and it measures to 999 Megohms. the old one my boss loaned out to me and my assesment testers only go up to 299 Megohms. Why do they go so high now?
Discuss Why do Megger MT1700 Teaters Measure IR to 999 Megohms in the UK Electrical Forum area at ElectriciansForums.net
so its not to comply with new regs or anything its just a manufacture quirk.
We use Chauvin Arnoux 5kv units that measures to 10T
Unless you are hanging on to the probes at the time.This seems to have turned into a willy waving contest.
I used to use a Kewtech KT65 which tests at 250v up to 199MΩ; and at 500v up to 900MΩ, not that I consider it anything to shout about
Give him an old wind up...…..he's good at that!Unless you are hanging on to the probes at the time.
The kt64 goes up to 1999 mega ohms at 500v test. But I'm not bragging.This seems to have turned into a willy waving contest.
one of my college tutours had a deep yorkshire accent, he also wore a bumbag, had a ponytail, had a constant look like he was surprisedUnless you are hanging on to the probes at the time.
199MΩ is plenty; >199MΩ is perfectly adequate. Anything more is just showing off.The kt64 goes up to 1999 mega ohms at 500v test. But I'm not bragging.
I normally put greater than 199 meg on cert if it goes over that to save on the extra ink used to write the other 9
>1000...…199MΩ is plenty; >199MΩ is perfectly adequate. Anything more is just showing off.
No one would notice if I waved that aboutThis seems to have turned into a willy waving contest.
Reply to Why do Megger MT1700 Teaters Measure IR to 999 Megohms in the UK Electrical Forum area at ElectriciansForums.net
