Why do we Bother | on ElectriciansForums
Discuss Why do we Bother in the UK Electrical Forum area at ElectriciansForums.net
Just been to a job to do some minor works and found the usual " boards just been changed" blah with no main earth, meter tails in separate holes in metal board plus a few other horrors.
I
Check out the page from the test cert and pictures of board.
[ElectriciansForums.net] Why do we Bother
Sent from my SM-G920F using Tapatalk
Any particular reason not to put most of the circuits on a RCD?
And why do we bother - thats simple - because we are professionals and we will always do it right.
As it's a contract job out of our area I've told them to get a proper electrician in after the weekend to test and put right, definitely not the builder from next door who's mate did this.
And no I definitely didn't connect anything of my new work to their system.
What a joke of a job that is.
1. Fed in T&E with cpc cut off. (you added the 16mm).
2. Cpc's just twisted together and in one terminal
3. RCD has only N connected but not L. Irrelevant as not covering any circuits anyway!
What a cowboy. Cant believe he left his details Inc mobile on cert. Might send him a text in a mo haha
Reply to Why do we Bother in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
This potential client seems to be making progress in terms of being interested in proper chargers and answering my query questions. I have also...
