why does 17th ed allow so much power per wire size than NEC? | on ElectriciansForums
Discuss why does 17th ed allow so much power per wire size than NEC? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
sandbox
here's one example. table 4d4a column 3 for 240mm2 shows 409amps/3phase.
at 380Y/220v thats = 155KW.
NEC table 310.16 for 75 degree C wire, 500MCM [thats 253 mm2] allows 380 amps/3phase.
at 208Y/120v thats = 79KW.
Why the big difference - almost 100% difference ???
the current capacity seems similar. is the lower KW value due to the lower voltage?
Your calculations are wrong and your not comparing like for like: 409A @ 380V = 269KW. 380A @ 208V = 136KW. If we make the voltage equal:409A @ 380V = 269KW. 280A @ 380V = 250KW.
Reply to why does 17th ed allow so much power per wire size than NEC? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
