Why does GFI pop when its engaged on daisy chain? | on ElectriciansForums
Discuss Why does GFI pop when its engaged on daisy chain? in the DIY Electrical Advice area at ElectriciansForums.net
South Carolina
Hi, trying to install a daisy chain of outlets & switches beginning the line with GFI. Whenever the gfi is engaged it pops the breaker.
The gfi has a 'line in' @ the bottom as specified in the instructions in the box and the top is 'load out'. The next outlet is connected from the load out of the previous ( gfi) then it goes into the bottom which is line in etc...
Set up is: GFI, outlet > outlet 1 > outlet 2 > outlet 3 > dual switches.
So the dual switches are the last on the line.
Need help finding out why breaker trips when GFI is engaged.
Any help is upmost appreciated.
  • [ElectriciansForums.net] Why does GFI pop when its engaged on daisy chain?
If the breaker is tripping you are likely to have created a dead short between hot/ground or hot/neutral. Looking at your wiring this doesn't surprise me, check there is no damage to the cables where they pass unprotected through the back boxes.
I apologise for the incomplete picture but it is protected by the outer coating which doesnt show in the picture.
Thanks we will look at everything again. ?
Hi thanks, could you please clarify?
Sorry, auto correct - it should have said 'a right mess'. Is that normal to just leave them bare and just twist them together? Certainly wouldn't pass UK regs.
I gotcha. Yeah it may not look pretty but thats the old way of doing things to save space in the box. By the time i shove the gfi in there's not enough room for a gray wire nut esp with 12 gage wire.
Still trying to find the source for the trip.
I would start with checking for continuity between earth and any hot wires.
Power off first
So is this a afci which is tripping.
Reply to Why does GFI pop when its engaged on daisy chain? in the DIY Electrical Advice area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
