I have installed a few QURW01 Quinetic 1 Amp WiFi Wireless Switch Receiver for Dimmer Switches in my home. Initially I had a problem with one low voltage (12v) ceiling light which turned out to be caused by exceeding the 1Amp maximum load, so I'm familiar with that limit. Recently, I installed another such unit to control 2 fittings each housing a
Philips 18W MASTER LED Bulb (100W Replacement) Warm White, Dimmable, E27 Edison Screw . So far, two units have failed with the same symptoms as previously experienced when I exceeded the 1 Amp max - i.e. permanently on and no response to the switch or kinetic app. Each bulb is rated at only 97milli amps, so I don't understand why the controllers keep failing.
Has anyone else experienced similiar problems with Quinetic controllers, or have insight into why they keep failing?
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
