Why don’t I do a bit of DIY | on ElectriciansForums
Discuss Why don’t I do a bit of DIY in the Australia area at ElectriciansForums.net
K
Knobhead
Why don’t I do a bit of DIY, simple if I reach up my back locks up and I go dizzy. It’s why I retired myself!
So the job!
It’s a flat so no access from above. There is a coving around all wall / ceilings. I don’t know if the cabling is run in that, it would make sense for it to be. To be honest I’ve never had a reason to find out, so I don’t know.
So the question is:
I want two or three picture down lights installed, switched from the normal switch position. All surface finishing to be made good. Certificates to be issued to relevant statutes.
Yes I could do it on my own, and better I think, but I’d be knackered, and as the regs stand I would be in the wrong
I will give a hand as and when I can.
PS you’ll have to put up with a GRUMPY OLD GIT providing snap and grog.
There’s a couple of you in the Nott’s area that I know of:
Fate favours the bold!
Reply to Why don’t I do a bit of DIY in the Australia area at ElectriciansForums.net
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
I use Xero for invoicing and sending estimates I use a different program (Quicken - not Quickbooks) as I have had it from 2004 and it still...
