why is new meter tripping rcd | on ElectriciansForums
Discuss why is new meter tripping rcd in the Talk Electrician area at ElectriciansForums.net
If its your supply meter you really need to contact you supplier as if its a loose connection its only a matter of time before it heats up it needs sorting ASAP.
Get them back before you start cutting seals etc(as it would of been resealed on replacment) or they will point the finger at you for tampering
Reply to why is new meter tripping rcd in the Talk Electrician area at ElectriciansForums.net
Ok I’ll try this when I’m down
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
