hello peeps,
got a quick question i would be most greatful to get an answer to:
Why do the requirements of the 7671 for PFC may not permit the use of a BS3036, semi enclosed device as means of covercurrent protection on a home re-wire
regard magy
hello peeps,
regard magy
Because the breaking capacity of a BS 3036 fuse is typically between 1 and 3kA so in situations where measured PFC exceeds this, the device cannot comply.
There is of course back-up protection from upstream devices but the above will answer the exam question.
so im i right in guessing this question is asking why we wouldnt choose bs3036 over newer RCDs?
and basically it because it doesnt have the right min disconnection times
MCBs, not RCDs! it's not just the disconnection time, it's also the low kA rating. MCBs are rated far higher in terms of breaking capacity.
why would you even want to use 3036 fuses on a rewire, anyway. that's like using a WWI biplane to combat MIG 29s.
North
why is the use of bs3036 not permited
paulthemagpie,
paulthemagpie,
