Okay, I know you have to use TT on a temporary building supply but cannot understand why? If the supplier is able to supply a TNCS why is this not preferable to a TT?
Discuss Why TT on Temp Building Supply? in the Electrical Course Trainees Only area at ElectriciansForums.net
Section 704. 704.411.3.1
A PME earthing facility shall not be used for the means of earthing for an installation falling within the scope of this section unless all extraneous-conductive parts are reliably connected to the main earthing terminal in accordance with Regulation 411.3.1.2.
NOTE If the PME earthing facility is considered for use, see also BS7375.
Reply to Why TT on Temp Building Supply? in the Electrical Course Trainees Only area at ElectriciansForums.net
