Discuss Why voltage is not increasing more than 2K in Megger MIT1525 Insulation tester? in the Electrical Tools and Products area at ElectriciansForums.net
Hi Sir, I'm having a Megger MIT 1525 15KV insulation tester. During testing test voltage is not increasing more than 2KV. these is no physical damaged to the equipment. what could be the reason? pls advise.
thank you...
If so, when there is a low impedance it will limit the voltage as to deliver more would result in a large current, as it is limited typically to 6mA
So 2kV 6mA would be circ 0.3 Mohm
If it isn't connected to anything and still not producing voltage (and you have the right settings etc) then it's faulty.
Edit: forgot to say, does it beep when you start the test (ie burn mode rather than discharge mode)?
Reply to Why voltage is not increasing more than 2K in Megger MIT1525 Insulation tester? in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for.
It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online.
Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
