why we use generator control module G.C.M.....? | on ElectriciansForums
Discuss why we use generator control module G.C.M.....? in the Australia area at ElectriciansForums.net
M
mateen
HI,
friend,...
i wanna ask you buddies why we use generator control module (GCM)....?
and where are we need generator control module....?
and what function is that...?
i wanna know complete knowledge about that...?
if some know about that so please tell me...
thanks advance
mateen uddin
electrical draftsman...
in kp & associates:mickey:
Generator Control Module is basically the heart of the generator system it will automatically start and stop the engine.
So on an emergency generator it will have sensor to detect a power failure, close down associated ATS switches and bring the generator on line. It will also allow for the generator to stabilize before coming on line to supply the installation
It will also supply you information the running status and if any fault conditions, also not only will they supply information, it should automatically shut down the engine under a fault
It should also give an indication of an engine failure on start up Most units will have a front panel display which will give you a local indication of above, but many modern ones can be ties into a BMS
Reply to why we use generator control module G.C.M.....? in the Australia area at ElectriciansForums.net
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
Hi sparks, this has probably been asked on here before but I couldn't find an answer using the search function. About to start my 2346...
