Why would a regular breaker work where a afci breaker won’t? | on ElectriciansForums
Discuss Why would a regular breaker work where a afci breaker won’t? in the UK Electrical Forum area at ElectriciansForums.net
So... if I was investigating this fault for a client, I would be asking the following questions...
Have you had any work done on the property in the vicinity of the cables/accessories it supplies?
Have you hung any shelves or pictures immediately before the fault developed?
What's connected to the circuit? It's possible, if something is plugged in that it's responsible for the fault
Have you got any outside lights supplied by this? If so, have you checked that there isn't a bunch of water sitting in them?
It's important to realise that a ground fault could be between the hot and ground or the neutral (I don't know what it's called in the USA) and ground. Could be as simple as a tiny pinhole/nick in the cable insulation where it was pressed up against a metal back box.
If you get an electrician in, hopefully they'll have a tester capable of carrying out insulation resistance tests which should allow them to identify which conductors are involved in the fault.
Don't keep resetting the breaker... if it's a sizeable fault (hot to ground for example), it's possible that repeated energisation could blow the ground conductor away. The net result of that would be that the breaker may stay on but everything after the fault could have lost it's ground and thus become unsafe.
As far as I know the term neutral is commonly used in the USA but the correct term is grounded conductor.
So in their code (regulations) they have the grounding conductor (earth) and the grounded conductor (neutral)
Which is just as good as us with the line and neutral both being live.
Reply to Why would a regular breaker work where a afci breaker won’t? in the UK Electrical Forum area at ElectriciansForums.net
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
Most manufacturers recommend them to be fitted. We are required to take that into account. If they had been fitted clearly it would have been...
