Just finished installing 20 x spike lights in a customers front garden. 2.5mm SWA ran from existing junction box feeding existing fence lights. All pulling no where near 1A in total.
When all connected and wiring tested, went to switch on MCB and it popped. Rendering the MCB useless as if L-N fault. Spend an hour going round checking every single connection and also to make sure no cuts in armour cores etc. All fine. Changed MCB and reset. Straight away it popped again.
I then disconnected all of the spike light load cables Line and Neutral. Reset MCB and all fine. The existing fence lights worked no issue. Connected in 1 spike light and reset MCB. Popped again. So I assumed this was a faulty unit, however it did this with another 3 before I stopped And began to pull my hair out.
I then got an LED floodlight and flexed it up, connecting it into the same connections as the spike light had been in, and it worked absolutely fine.
The customer then asked me to fit a plug top to a new spike light, which was the same but never fitted as it was extra , I did and when switched on it popped the MCB and rendered the socket outlet useless.
The spike lights are 7W LEDs with a black 2core flex brown and blue cabling. I even tried reverse polarity on them and still the same issue.
I pretty much put it down to faulty lights, but the fact there is 20 of them is making me second guess myself. Anyone here have any experience with this ? I have 16 years experience and never heard anything like it.
Any help appreciated.
Nick
NEB Electrical Ltd
Nick
NEB Electrical Ltd
