Why?
diditrain
Working with a colleague today who drilled through a leg of RFC, not in a safe zone. The 30 Amp 3036 failed to operate, however the BS88 100 Amp service fuse ruptured.
If all power was not isolated e.g lights, heaters then it might not have taken more than 30a of fault current to blow the 100a main fuse.
ah , but these clever little 3036 fuses were programmed to only blow on a shorted cable in a safe zone. hee, hee.
I cut through a live 2.5mm cable in a loft once and it blew a faulty joint under the street! Bypassed the 30 amp 3036 fuse and the 100 amp cut out.
Which fuse modification is best I wonder
Does tin foil from a smoke packet have the ability to withstand higher fault currents than the paper clip ?
What about the 6" nail,is it able to discriminate with the foil, surely the sequence should always be
Foil in the plug top,paper clip in the fuse board and a 6 " nail for the meatier supply fuse,anyone think differently ?
The history of these fuse adaptions is also varied according to the Wiki site
Foil is getting much easier to obtain with the advent of the roll variety,especially for cooking the bacon,it was rare at one time,found only in Woodbine packets
Paper clips were possibly only made of wood, so have no real history,especially when compared to the 6" nail, which along with its use as a service fuse,was found to be ideal for making wood stick to other pieces of wood,but its original service fuse use will continue until a better alternative can be found
These adaptor items have been known to save on possible costly and usually un justified employment of electricians
With the demise of the trade,its probable,fuse adaptors and their use will continue to flourish
My old boss cut through a 6mm, live on a 30A 3036, blew the arse out of his cutters, went and got his other cutters, assumed the fuse had gone, cut it again, another ruined set of cutters and circuit still live.
Another one Ive seen is an open backbox with a 6mm in a TB filled with wet plaster, someone complained it was smoking while the plaster was drying out. When I went to the job all the clips holding said 6mm to the joist in the garage appeared to have melted, circuit still live. Both occasions the fuse had 30A fusewire in it.
