Wi-Fi TV hookup using existing cable jack | on ElectriciansForums
Discuss Wi-Fi TV hookup using existing cable jack in the DIY Electrical Advice area at ElectriciansForums.net
coopfab
MA
The room where we’re going to install a Smart TV has an existing cable jack but on the wrong side of the room. I want to convert the cable jack to an ethernet connection to where I’d attached a Wi-Fi range extender. Does my scheme make any sense? Is it at all doable? Thanks in advance for your interest and suggestions. MAC.
Yes, if I understand your terminology it sounds OK. What you call a "cable jack" is that an RJ45 wall outlet, and if you plug something into there you get Internet access? If so then you can certainly connect a wireless device to allow your TV to connect over wireless. What you need is a wireless "Access Point", that plugs into the wired network and allows wireless devices to connect. Typically a "range extender" connects by wireless as a repeater or similar.
Reactions: DPG
Thanks very much for you reply and interest. Attached is a photo of the internet coax connector that I'd like hook up a wi-fi extender that has a built in female RJ45 jack. Is there an adapter or connector that will go from a male coax connector to a female RJ45? Any help you could give me would be most appreciated.
  • [ElectriciansForums.net] Wi-Fi TV hookup using existing cable jack
I think the problem here is that you have an f connector supplying your broadband. This cannot be directly adapted to an RJ45, but will need some sort of cable router. This could then feed a range Extender.
Thanks for your help. Don’t think my idea will work, we already have a router, too far away for a good wi-if connection, and my guess is Xfinity won’t allow two routers in one house. Again, thanks for your help and interest. Coopfab
Reactions: DPG
you need to run ethernet cable between router and tv, that connector on the wall is of no use to you unless you move the cable router to it instead of where it is now. (assuming it is a cable connector not a satellite connector)
Reactions: DPG
Thanks James. I get it now.
Reactions: DPG
Reply to Wi-Fi TV hookup using existing cable jack in the DIY Electrical Advice area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
5K
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
