Does anyone know of a product similar to the Integral LED 70-100mm range (linked) that allows you to adjust the lamp direction? The client has a few that are shining onto paintings, but we would like to be consistent with the bezel size.
Integral LED 70-100mm Cut Out Evofire IP65 Fire Rated Downlight
For safe, stylish and reliable lighting that’s easy to install with a 70-100mm cut-out, this Integral LED EvoFire fire-rated downlight is the perfect choice. The ultra-thin 1mm bezel fits flush against the ceiling for a discreet and attractive finish, while the canless design helps the lamp run...
www.toolstation.com
