Wide SDS Chisel | on ElectriciansForums
Discuss Wide SDS Chisel in the Electrical Tools and Products area at ElectriciansForums.net
T
tombrooker84
Hello Guys,
Just read a thread on chiselling in back box, and been looking at wide sds chisels, are they any good, are there any particualr brands you stick by?
Regards
Tom
Hi Tom
got some really cheap tat years ago and they've gone through many houses, factories and the odd engineering brick and still fine.
So I wouldn't (in my humble experience) pay too much.
Armeg are good, but Heller are as good and cheaper. Forum won't accept the link, check the Toolstation catalogue or website.
I have the armeg wide hard material chisel which is pretty good and is the same width as a single back box, so is quite easy to use. Because it's for hard material you have to be careful on softer materials.
Reply to Wide SDS Chisel in the Electrical Tools and Products area at ElectriciansForums.net
Yet another vote for the biggest and the littlest. I use the big SDS solely for chasing (you still need it if you have a chaser as it doesn't get...
W
Pan connector to soil, not sure what needed Hi all, Need to change this pan con and am not sure what I'm looking at where the pan con and the...
WaterTight
W
