Good morning. I intend to replace my oil boiler with electric and a qualified electrician will be doing the job. I see there are lots of din rail mounted WIFI devices such as meters, switches, timers etc and I am considering asking the electrician to incorporate such devices within the new consumer unit feeding the boiler, immersions and controls. This is for 'smart home' remote monitoring and interest in energy consumption purposes.
Anyone had experience of these devices within a metal consumer unit where the WIFI signal may be proved ineffective due to the metal enclosure? I appreciate strength of WIFI signal may come into play here.
I assume a plastic enclosure is not allowed. Thank you.
That is a very good point.
The makers of these Wi-Fi devices should, and maybe do, state plastic enclosures only.
Electrician regulations ask for metal consumer units…. (Doesn’t actually state that, says non fire propagating or something)
Even without the metal enclosure, the Wi-Fi will be affected by interference through close proximity to mains voltages running through the circuit breakers.
Thank you Newfutile & littlespark.
I will see what the manufacturers suggest regarding enclosures. I would have thought that as they are din rail mounted that they are assumed / likely to be incorporated within a CU and therefore take into account such as metal enclosure, but perhaps not!!
Again, as these devices such as the meters and timers etc have the mains voltages running through them I guess the manufacturers would have taken possible interference into account somehow.
It is an interesting point and I think the din rail wifi meters, timers and switches can make for a very tidy arrangement in a CU , but only if the 'smart home' remote monitoring and control wifi works of course.
It would be good if someone has direct experience with these devices in metal CU, nothing like first hand knowledge. Perhaps I could ask the electrician to initially incorporate the devices into the CU and lay it out such that if the wifi element doesn't work he could strip or swop the devices out easily and I just forget about the 'smart home' stuff.
I've fitted a couple into metal CU's. Best at the end of the DIN rail given busbar arrangement. Once next to a and 6A RCBO and most recently in a duplex board where only the top row was populated, so the device was on the bottom next to blanking plates. With the last one the router was in another room about 10/12 feet away. Wifi worked fine. It's a holiday home and the customer has no issue accessing the device - he's 600 miles away. If I had several to fit I't use a plastic enclosure.
DIN rails are a standard for mounting devices in any enclosure… not just consumer units…. So it’s not a case that the devices are designed “only” for CU’s.
Yes, they might work but it could all depend on what is being fed from the board…. Could be many things switching in and out, changing that causes interference rather than a steady load.
Thank you richy3333 and littlespark.
The house has the 'usual' split rcd protected consumer unit (but it is plastic as 2013 refurb) at the cable entry and my thoughts are to run a new radial from this CU to the new boiler/cylinder ventilated cupboard. The plastic enclosure makes sense so if I consider this as a boiler supply distribution board rather than a CU, would this be compliant?
Something like MCG 12 module Insulated Enclosure with access window and DIN Rail or perhaps the Hager Vector 10 Module Insulated IP55 enclosure with earth & neutral bar that google throws up. The electrician will of course have final say and I am just interested to see what may be acceptable before I put it to him, hence my query and I trust you dont mind me asking the question.
Wifi is remarkably resistant to interference, the issues regarding electrical noise and interference would make a huge difference if you were trying to transmit time critical data, such as a telephone call or live video.
however if you are doing home automation or data logging, then having the data repeated several times until it is transmitted properly is not an issue and for that to happen, then a 1/4 second delay in the data is unimportant.
Thank you for the information, James. I am not considering anything critical, simply remote monitoring and occasional switching/changing time schedules and the like.
Personally I would consider the 'boiler supply DB' to be an another CU under domestic environment if you are supplying it with 230V so I'd think it needs to be metal. Could you run a radial to an FCU and then the FCU to a plastic CU. My initial feeling is that this would be oK?
Thanks for info richy. Space is not a problem so a FCU could be installed adjacent to a plastic CU. I will indeed put that as an option to the electrician and see if he is comfortable with that.
Thanks again for your input.
Ive installed some battery operated WiFi temperature sensors inside cold store/fridges and they work perfectly well but it might be a suck and see job depending upon WiFi signal strength!
Thanks DefyG. I am thinking along those lines insofar as I will ask the electrician to build the DB/CU (plastic if he is OK with that) incorporating the wifi devices but with a 'remedial' plan if the wifi doesn't work.
Surely this is not actually a CU or DB? The protective device is in the main CU, presumably a B6, otherwise a 3A BS1362 in adjacent FCU? If that is the case, the enclosure for the smart kit is directly equivalent to a Wiring Centre, and as these are invariably of plastics material, using an insulated enclosure for the clever stuff is not an issue.
Thanks for thoughts GroovyG. The electric boiler is actually 6kW so the set up is B50 MCB in main CU which supplies the Boiler CU/DB (depending upon what we want to call it). The contents of the Boiler board is B32 for 6kW boiler, B16 for Immersion and a couple of B6's for controls and boiler cupboard light plus a couple of din rail smart meters / timers / switches. I propose a CU for the boiler board simply for convenience of mounting the kit but then thought about the WIFI devices within the metal enclosure perhaps not being a clever idea. The electrician can decide what he is comfortable with but like you say, there are plenty of electrical components / devices within plastic or GRP enclosures. The work will be getting done next month so I will respond with final arrangement / performance.
Perth
United Kingdom
WIFI devices in a metal consumer unit.
DIY Electrical Advice
LawVal,
Strangehead,
