eselick
Hi
I'd like to install a 240 volt single phase sauna stove at a distance of about 200 ft from my main panel. The main panel has a 40 amp GFI breaker and an 8/3 exterior wire that goes into a sub panel in my workshop. The 8/3 is inside of a black 1" pvc 50 ft long flexible water pipe. I'd like to put another 40 amp breaker in the sub panel and extend the 8/3 wire to the location of the sauna which will be built about 150 ft from the workshop on a structure that will be built over a pond.
Another consideration is that the sauna stove, according to the installation manual, will not function correctly with the GFI breaker which would need to be swapped out in the main house panel. Nothing would be running in the workshop when the stove was on.
My question is whether the sauna stove will not function or be damaged by the voltage drop at that distance. Is a reasonable project to undertake?
Elliot
Elliot
