will this cable work | on ElectriciansForums
Discuss will this cable work in the Australia area at ElectriciansForums.net
O
ob1
Hi all, Is it possibe to use BS7870 Cable for use from supply directly to a machine?
Also is it is 95mm would i be right in thinking it doesnt come in below 4 cores?
thanks in advance
the full spec is BS7870 -3.4
By location i meant what type of enviroment was the m/c located in ,ie is it wet,is it hazardous ,is it dusty,
i don,t think the cable is suitable i would be looking at bs 5467/6724 .Size 95mm could be ok but you don,t mention how the cable is to be installed (grouping factors /method of installation ).Can you terminate a SWA cable directly into m/c, what about local isolation ,where is it to be fed from ?.
Not trying to be awkward but to spec. a cable you need to know every detail.Personally i would fit a 150a isolator adj.the m/c install SWA cable to isolator and probally something more flexable from isol. to m/c
yours benji
yours benji
Hi benji, Its in a nice clean factory, would of course be putting it on an isolator, but finding out the cable is 3 core its actually definatly no good to me.
thanks alot for your help
Reply to will this cable work in the Australia area at ElectriciansForums.net
It applies to commercial if it shares the same supply as a dwelling.
dreadful, I couldn't sleep at night after that install, it may just about pass but the quality of work is substandard IMO
