Wind loading calculations | on ElectriciansForums
Discuss Wind loading calculations in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
P
Paul Cambridge
Hi,
Has anybody performed wind load calculations on PV panels? We have to quote for a job located very near the sea in an exposed location. Concerned about environment.
Paul
Yes we do it on every job, if you need someone that can do it pm me.
Reply to Wind loading calculations in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi My first post here, so apologies for any mistakes. I think it will be DIY job with electrician sign off if required, but would like to do as...
Well conventional wisdom says that you just parallel ('piggy back') as many switch sources as you need, all fed to the contactor coil. If for...
