M
march1971dogs
Hi found your forum because im looking for some help :mad2:
i live in france and renovating a barn i installed speedfit underfloor heating and all speedfit sundries including the wiring centres jgh1 no problem this is where im stuck,i bought second hand windhager pellet boiler mod number bwe260 ,it has only single feed live neutral earth , has anybody wired one up before ?
i cannot get my head round it
how does the boiler fire up does the boiler enable wire from wiring centre go to the circulating pump (exsternal pump as none inside boiler)?Then in turns flicks flow switch inside the boiler to fire then heats the water in the buffer tank ? If so what cuts the boiler out as the thermostat wired to the wiring centre
or have i made big mistake and missing something.im sorry im not a trained spark and using your forum but just hit dead end with this one.
thanks peter :mad2::mad2::mad2:
