Window actuator wiring | on ElectriciansForums
Discuss Window actuator wiring in the UK Electrical Forum area at ElectriciansForums.net
london
hello people
I need to wire up a window actuator, I just want to check something.
The window actuator came with a two way retractable switch and from the wiring diagram attached my thinking is:
GREY - connector block to neutral in switch
BROWN - onto L1
BLACK - onto L2
**ill swap L1 and L2 around depending on direction.
It looks quite simple am I wrong?
[ElectriciansForums.net] Window actuator wiring
You would be correct, are you asking because the diagram does not specify L1 and L2 thus you worry about your connections are correct?
I would think the actuator can be referenced visually to get this correct or using a multimeter then simulating say the open option and ensuring you nail it first time.
Reply to Window actuator wiring in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
Can you do a sketch of the wires and their connections but @littlespark is probably correct.
