Wire in flex!!!Hi | on ElectriciansForums
Discuss Wire in flex!!!Hi in the UK Electrical Forum area at ElectriciansForums.net
Welcome to the mate.
Please can you give us a bit more info.
What CSA is the cable? What is it supplying? Is it coms or power. What route is the cable taking? Anything else you would like to add may also help.
Depends on what type of cable he is thinking of using and what for Pete. Lets see if the OP answers my questions.
Hi thanks for replies
fed in 3c 1.5 flex
circuit runs in galv trunking and tray work
protected by 16a type b mcb
switched via a 20a contactor
not found what it's switching yet but most probably doing some stage lighting in the theatre area, on a rig
Not worked in the theater area ever, doesn't the cable need to be reinforced in some way? as I say this type of work is specialised isn't it, could be wrong just not sure.
fed in 3c 1.5 flex
Isn't the mcb labelled to say what the circuit is?
What's wrong with using flex in trunking or cable tray?
Where is the trunking & cable tray located?
seems like theatre installation electricians just use what's on the van
Hmm, a sweeping generalisation there I think, or maybe you just haven't seen one of our jobs yet:)
Reply to Wire in flex!!!Hi in the UK Electrical Forum area at ElectriciansForums.net
Its important to remember that a plug top fuse is just a rewireable fuse that's convenient to change and shouldn't be confused with a HRC fuse...
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
