Wire in the in-built wardrobe's wall vs regulation | on ElectriciansForums
Discuss Wire in the in-built wardrobe's wall vs regulation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Warwick
Hi,
I'm new to this forum and have no electrical experience but would like to pick up some knowledge on the following issue.
I've had an in-built wardrobe in one of the bedrooms in my house which needed removing. Upon tearing down the walls I found out that majority of the electrical cables ran in the wall of the wardrobe (it's not even a room wall) - photos attached. The cables go into the attic and then to all the rooms in the house. The room itself is right under the stairs.
This is a new build property and I wanted to ask if such a cable arrangement is complying with the regulations? As I can't think of a worse location for laying the cables in the walls. I just want to know if this was laziness on the part of the developer but legally OK or I can report it and have the cables relaid properly.
Any help will be much appreciated.
[ElectriciansForums.net] Wire in the in-built wardrobe's wall vs regulation
What’s your intention for the cupboard - it’s not like it has a floor or anything!
It’s technically the airing cupboard but without the immersion of old. Lots of people put a tubular heater in there and store towels etc.
Were the cables visible from inside the cupboard?
If not, then the route did not comply.
The cupboard took up 1/4 of the room. I wanted to put up some plain shelves on the wall where the doors are and then cover the most of the slant with the DIY bed frame that would go along the wall.
Sorry, I may have jumped the gun there.
There are a number of requirements for concealing cables in walls.
One is that they are at a depth greater than 50mm.
Another is that if they are at a depth less than 50mm, they should be run in a prescribed route and be protected by an RCD.
What is the width of those lengths of timber, and what is the distance of the holes from the edge of the timber?
The width of the timber is ~95mm. On top of that, there was a 12mm or 15mm plasterboard, either side of the frame. However, that lower beam was drilled at a really funny angle, certainly not in the middle.
Hi - it doesn't look like they've been run in the zones for cables but the pic suggests the added framing and plasterboard may achieve the >50mm depth exemption. If so, it probably complies.
I would think the cupboard walls are made the same as any partition wall in the property regarding width.
I don’t think they are in the wrong place, and it’s going to be a pain having them moved now
I cant see how it can possibly comply? They are clearly not in a correct zone. Its tempting to say 'why have they done it like this!', perhaps there is a reason but I expect it would have been easy enough to run then within 150mm of the wall, so I'm not sure why they didn't.
Reply to Wire in the in-built wardrobe's wall vs regulation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
I have to agree with littlespark stating that the wires should be absolutely cut loose at the fuse or breaker to make it safe. The heaters should...
