Wireless Electrical Relay
N
Neil O'Connor
Anyone ever hear of a wireless electrical relay?
I am upgrading my heating controls to have 3 zones.
2 Rad zones and 1 HW zone. As this is an upgrade i am going wireless to avoid running cables. I already had a 220v supply in the hot press and was able to use wireless programmable thermostats to control the motorised valves.
My problem is in order to do the job right i need to have the motorised valves sending a signal to the boiler to bring it in when ever they are open.
There is no hope to run a cable to the boiler so what i want is some sort of wireless relay.
i.e. when the N/O volt free contacts in the valve are closed the relay transmitter picks this up sends a signal to a receiver relay (at the boiler) which closes it's volt free contacts (engaging the boiler).
Anyone ever hear of such a thing?
Seems simple enough (similar technology in fact to the wireless thermostats).
Cant seem to find anything on-line though.
Is the new valve in close proximity to the existing valves & wiring centre???
You may not need a new cable to you boiler if you can get at the connection of the existing valves....
