wireless light switching | on ElectriciansForums
Discuss wireless light switching in the Australia area at ElectriciansForums.net
Colne, Lancs
Got a small problem i've recently wired a large and expensive kitchen for a client who has now request some lighting above a larder area on the opposite side of the kitchen to the pelmet lights ive already installed on the other side. Does anyone know of a wireless transmitter that i could use to connect the lights on the other side because i can't damage kitchen in any way and they want them all to come on together.I thought of using a transmitter to switch a relay to turn on the lights at the other side but if anyone has come across this problem before it might help
Thanks Strickers
i have fitted a wireless switch before i think it was a newlec type, it works on a frequency signal, aslong as u hav a perminant feed at it it stays on the frequency, it was quite gd and would probaly do the trick, u would need to watch the distance between the transmitter and the switch, try screwfix.com to c if they hav any in stock,
Reply to wireless light switching in the Australia area at ElectriciansForums.net
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
Figured things out. Thanks for the help. Original wiring only had one wire going to the bottom of the left switch. Found some spare wire and...
